newbie cd changer questions
Old Apr 26, 2006 | 04:49 PM
TEX02SS's Avatar
Default newbie cd changer questions
i just bought an 02 ss with the monsoon system. It does not have the factory cd changer. I read somewhere that the wiring should be run back and that the harness can be found on the driver side in the rear cargo area. I looked and all i could find was the wiring for the rear lights. Am i just overlooking it or are not all of the 02's pre-wired for the changer. Also if anyone has the part number for the changer that will work with my system, it would be GREATLY appreciated. It seems there are a lot on ebay but i'm not sure which is compatible. Thanks in advance.
Old Apr 26, 2006 | 05:53 PM
2001NBMZ28's Avatar
Mine didn't come with the remote CD changer, but has the harness. Remove the drivers side sail panel and doublecheck - should be there.
Old Apr 26, 2006 | 08:25 PM
TEX02SS's Avatar
found it....it was bundled up with the rear speaker wire...not run all the way back to where i was looking....now if i could just get the PN for the changer im set
Old Apr 27, 2006 | 11:41 AM
2001NBMZ28's Avatar
http://www.ls1tech.com/forums/showth...onsoon+changer See post #2
Old Apr 28, 2006 | 03:17 PM
TEX02SS's Avatar
thank you VERY much
