Infiniti 6012's
I recently blew out one of the door speakers in my 2001 SS w/ the monsoon system. I decided to take off the door panels lastnight and see what was going on, obviously just as I thought the speaker was blown. I went over to bestbuy and picked up two Infiniti 6012's to replace the speakers in my front doors. My question is this. The stock speakers have four wires (two for the tweeter and two for the sub portion), and now the speakers I have only have provisions for two wires. Which two wires do I hook up to the new infiniti speakers? The 6012's have tweeters built into them as well.
I am sure these are not the best speakers to use and Im sure there are plenty of opinions on what else I should be using. I am not going for an all out system just looking for something equally as good as what I had in there. Hopefully these speakers are at least on par with what came out of there. Please let me know how I should wire these speakers. Thanks!!!!!
-Jamin
Here's a thread for this mod: https://ls1tech.com/forums/showthrea...t=instructions
When I asked him about the wiring, he said that they will supply me with a wiring harness that should just be plug and play.
Anyone ever use them for this setup.
He also said, by just adding these speakers to the factory unit will be a huge plus.
-JZ
The write up in the above link spelled things out perfectly. Overall the $99 I spent on the speakers and an hour putting them in was well worth it. If anyone has any questions let me know.
-JZ
They are very easy to install and a great price ($99). If your thinking about new ones these are very decent for the money. If you are mechanically inclined at all and know how to use a soldering iron you wont have ANY problems rewiring the speakers. I was alittle nervous about it but once I jumped in it was very easy. Just take your time and you will be fine. You can use the soldering iron to unsolder the factory connections and then redo them according to the link in the above post.
-JZ
