Which subwoofer Should I Choose?
My Choices:
8" Subwoofer:
• 400W Rms
• 800W Max
• Dual 4-Ohm Voice Coils
• 200 Oz. Double Stacked Magnets
• Tuning @ 40Hz
10" Subwoofer:
• 250W/300W Rms
• 500W/600W Max
• Single 4-Ohm Voice Coils
• 50 Oz. Single Magnet
• Tuning @ 40Hz
12" Subwoofer:
• 300W/350W Rms
• 600W/700W Max
• 60 Oz. Single Magnet
• Tuning @ 40Hz
2 Alpine DVC 10's (SWS-1022D) 300 Watts RMS/900 Watts Peak
MTX 6500D 610 Watts RMS
Subthump Driver and Passenger Side Stealthboxes
I have used sealed and vented boxes with the Alpine 10's and vented is better. I also used the MTX Thunderform CF10 and it wasn't to bad. These already come loaded with a MTX 10" sub. It comes down to what you are looking for out of your system. One 10" sub can easily overpower the rest of the stock audio system.
The 8" would most likely be a poor choice. If you have a good quality tube, the transmission line design of the better tubes is actually a rather good enclosure. So going to a 8" in a different arrangement would probably end up being about the same.
In the end, I am also confused why you are looking to avoid using a stealthbox. They are well proven, and if you load it with a solid 10" and put a strong amp behind it, it is proabably right at what you are looking for. No issues with losing space, proven designs that are as compact and light as possible while still allowing for proper loading of a 10".
Get a used one (it's hidden so appearence isn't exactly critical), and go big on a solid 10" and a class D amp. Most people would agree this is the way to be going, unless you are trying to really scrimp on cost.
I am also a little leary of the specs you are listing for the drivers. Specs aren't everything - you can't just go off of the numbers and use those to A-B different drivers. Manufacturer specs get really hokey, especially if you are dealing with lower end vendors.
Dual voice coil just gives you more wiring options, it is not an indicator of performance or frequency responce.
A properly designed ported box will be more efficient (louder) than a sealed box, but the box size will be larger and all subs are not well suited for a ported box, again driver specifics are needed for a properly designed box, and the proper box will vary from sub to sub, there is no one size fits all box. Aslo, not all manufacturers give good (good being determned by your specific goals) recomendations for a ported box. Some of the suggested ported boxes are aimed at high SPL at the expence of frequency extension and SQ, while others are more geared to SQ and good extension. Unfortunately, most don't tell you which approach was used in the box design, It is always a trade off, thats just how the physics work. Sealed box recommendations are always (from what I have seen anyway) pretty good, and it will have good SQ. Another big plus of a sealed box is that if you build your own box, sealed is much harder to get wrong.
You also need to decide what kind of bass you want, do you want a boomer that kicks you in the chest and impresses the other kids (ported is a good choice here) or flat frequency responce that sounds natural and blends with the factory system (assuming the rest of your setup is stock), I am guessing a boomer (nothing wrong with that) but you need to know what your goals are to get the right system.
Don't assume that because a sub can take more power that it will be louder, it simply isn't true. This is again where the TS and box parameters are needed to determine what the output and frequency responce will be.
Also, what is your budget? Can you build the box yourself or do you plan to buy one? What are your box size limitations?
I personally run a pair of 8" subs and am happy with them, but you really have to do your homework on 8" subs to get something that will play low and/or loud. Mine are about the equivalent of a single sealed 10" - 12". Many are listed as subs but should actually be classified as mid-woofers. If you really want an 8" I can point you to a few good ones, but you will have a lot more good drivers to choose from if you go with a 10" or 12".
A few more specs on the subs:
8"
• Mounting Depth: 4.6”
• Mounting Diameter: 7.3”
• Optimum Vented Box: 1 Cu/Ft
Round Port Diameter: 3” x 9”
Square Port Area: 2” x 4” x 11”
• Optimum Sealed Box: 0.65 Cu/Ft
10"
• Mounting Depth: 5.6”
• Mounting Diameter: 9.2”
• Optimum Vented Box: 1.75 Cu/Ft
Round Port Diameter: 4” X 9”
Square Port Area: 2.5” X 6” X 11.5”
• Optimum Sealed Box: 1 Cu/Ft
12"
• Mounting Depth:
• Optimum Vented Box: 2.25 Cu/Ft
Round Port Diameter: 5” X 11.25”
Square Port Area: 3” X 6.5” X 12”
• Optimum Sealed Box: 1.25 Cu/Ft
I am unsure of the sensitivity rating on each but each of these subs are in the high 80's low 90's db sensitivity range. Thanks Again.
I could go on about the insanity that happens when I turn mine up.....
You get the picture, I didnt mean it literaly broke the windows but the car was a rockin! No doubt Adire are supposed to be one of the best, wish I had one to compare.
Dual voice coil subwoofers are becoming a popular choice among car audio enthusiasts who want more flexibility in wiring their sound systems. While typical subwoofers have a single voice coil, dual voice coil (DVC) subwoofers use two separate voice coils, each with its own connections, mounted on one cylinder, connected to a common cone.
The key difference between single and dual voice coil subwoofers is the multiple wiring options DVC subs offer:
Parallel: A dual 4-ohm voice coil subwoofer with its coils wired in parallel presents a 2-ohm load to your amplifier. Since an amplifier produces more wattage at a lower impedance, the parallel connection ensures you'll get the most output from your amp. In the same fashion, if you have a stereo amplifier and two DVC subs, wire both subs for 2-ohm impedance (one per channel) for maximum output.
Series: Series wiring lets you configure multiple woofers to one amplifier at an acceptable impedance. Wire both coils in series for an 8-ohm impedance, and then wire two 8-ohm subs together in parallel for 4-ohm total impedance (perfect for most 2-channel amps bridged to mono operation). Another example: if you have a high-powered 2-channel amplifier, wire four 8-ohm subs per channel (each channel sees a 2-ohm load).
Independent: You can wire each voice coil to a separate channel of your amplifier, if you prefer not to bridge your amp. Independent wiring is a nice option if you're wiring two DVC subs to a 4-channel amplifier — one voice coil per channel.
DVCs and high-performance amplifiers
Some amplifiers are designed with an unregulated power supply — these amps are favored by mobile audio competitors for their superior performance. An unregulated amp's power increases dramatically when it sees a lower impedance load. For example, an amplifier that produces 75 watts RMS x 2 channels at 4 ohms would double its power to 150 watts x 2 with a 2-ohm load. DVC subwoofers (particularly the dual 2-ohm models) give you the flexibility to wring every bit of power out of this type of amplifier.
Also, if you choose to add an unregulated amp as a power upgrade to your existing DVC subwoofer system, you can simply rewire your subs for optimum impedance. Remember that most car amps are stable down to 2 ohms in normal operation, and to 4 ohms in bridged mode. It's important to check your amp's manual for its operating parameters before hooking up a DVC sub wired for low impedance!
A DVC sub offers the same performance whether it's wired in series or parallel. Its power handling levels, frequency response, and other specifications do not change — the only difference is the impedance presented to the amplifier. As a result, you'll use the enclosure that's recommended for your sub, no matter how it's wired.
sorry to disagree with you but 12's do not hit the hardest... if you check termpro or anything else 99% of the extreme records are all 15's... and as far as a ported box being to big... that all depends on what your building it for...
most ported boxes are only a bit bigger for a SQL box, I just grabbed JL's specs because I had them on my computer from helping a friend design his box...
10w7
1.25 sealed
1.5 ported
12w7
1.375 sealed
1.75 ported
13w7
1.875 sealed
2.375 ported
and that isn't very much bigger esp. if you used a slot-port instead of a round one...
Like I recommended earlier a good 10" will be enough for most people in an f-body, heck I bet some of the 8's out there would do it Adire/RE/ID...
edit. oh and cerwin vega FTW. new stroker pro. get it. also US AMPS. ill probly never own another brand.
my recommendations: nakamichi. best sounding stuff i have ever heard. exspensive and hard to find, but my next system will have mostly nakamichi. i personally have cerwin-vega components and a cerwin vega stroker. sounds amazing.
