Post pics of stereo power wire to battery
Old May 14, 2006 | 10:50 PM
LS1FIRE's Avatar
Default Post pics of stereo power wire to battery
Hello i am looking for pics of your stereo system power wire going to the battery.
I bought a subwoofer from a stereo shop couple years ago, I had some porlbmes with the power wire to the battery after couple of years.
They smashed a wire clip fitting that the power wire connects to inbetween the main red rubber power line fitting that bolts onto the battery with an 8mm bolt,after a couple of years i had problems with the postive connection of my battery because of the stereo power wire washer fitting was smashed onto the main rubber battery termnal and which cause for a bad connection and had my car die out on the freeway. I plan on placing the power wire onto the stub on the battery. Im curious to know how yall have yours hooked up?
Old May 15, 2006 | 09:41 AM
OneFast97Z's Avatar
Power wire connected to positive connection box next to power steering resivoir
Power wire routed into car through pcm gromet
Old May 15, 2006 | 11:47 PM
98boxer's Avatar
you can also pics of at my car website, of how to run the wire through the fire wall
