need help installing a sewart warner digital tach
Old May 21, 2006 | 12:09 AM
kyles2000z's Avatar
Default need help installing a sewart warner digital tach
just boughta used SW digital tach w/o instuction so i was wondering if anyone had a write up on how to get this thing installed. im not having troublle with the ground or 12 volt source, i just wanna know how to connect the wire to one of the coils.
Old May 21, 2006 | 01:14 AM
SweeTbone's Avatar
https://ls1tech.com/forums/showpost....14&postcount=3
3 wire hookup. + , - , and Pin #10 right out of the lower (red) connector on the PCM. It's a white wire that will be tapped and go to the tach signal on your tach/shift light.
Old May 21, 2006 | 07:54 AM
kyles2000z's Avatar
thanks man, that seems to answer my question.
Old May 21, 2006 | 06:28 PM
SweeTbone's Avatar
Kinda squeeze the sides and pull it right out. When you flip it over, you will see some small #'s above each wire in sequence. They may have a little corrosion on them, but I scratched it off and found the #10 white wire. The orange gasket may come off, just put that back on the CONNECTOR then hook your connector back up to the PCM.
Old May 21, 2006 | 10:23 PM
kyles2000z's Avatar
thanks for the help, just finished everything up.
