help me with my blinkers please
Old May 25, 2006 | 04:49 PM
jeff00z28's Avatar
Default help me with my blinkers please
All of the bulbs light up, but they dont blink. The right one is working off and on, and the left one just stays lit but doesnt blink. Help asap, thanx in advance.
Old May 25, 2006 | 04:57 PM
TheShadiest1_'s Avatar
I am pretty sure you have a bulb that is blown. Probably in your taillight.
Old May 25, 2006 | 04:59 PM
jeff00z28's Avatar
Thanx, so bulbs can still be bad even if they light up?
Old May 25, 2006 | 05:02 PM
I think they are dual filament, so one level of lighting may work, but the other may be blown. At least thats what it was when I had that same problem.
Old May 25, 2006 | 06:24 PM
jeff00z28's Avatar
I changed the bulbs on the side that wasn't blinking, and now both sides arent blinking. Sometimes the right side will blink really slowly. How do u change blinker fluid?
Old May 25, 2006 | 10:24 PM
VIP1's Avatar
Copy & Paste Moderator
The bulbs are dual filament.
There are two flashers:
* One is for the hazards
* The other is for he left/right signals
Turn on the hazards and look for any bulbs that are not flashing (that are supposed to flash) or flashing irreguarly. Inspect that bulb and its socket. Replace the bulb or clean off the socket's corrosion (which ever is needed). If all the bulbs appear to work properly, replace the signal flasher.
Old May 26, 2006 | 07:03 AM
Duffster's Avatar
It's the flasher relay. . .
2 phillips screws and 2 7mm screws below the steering column.
remove the knee panel and there are the relays to the right side.
Don't remember the part number, but any Napa will have it.
Won't take you literally 5 minutes to replace. Also shouldn't be
more than about 6$ to replace.
Leave the panel off until you know you've got the right one
replaced.
Enjoy!
Duff
(Yes, the bulbs are dual-filament bulbs)
(Yes, the lights will come on w/one burnt out)
