My Ipod Install
I Decided to set it up in the ash tray. I removed the tray and the light bulb assembly thats in there. The ipod slides in smooth and sits flush with the edges of the ash tray. Currently my Ipod has one of those pda screen protectors on it but I'm going to have to get a bigger one that I can wrap around the Ipod so that the sides dont get scuffed up from inserting/removing the ipod from its new bay. When I change tracks the Ipod lights up and shows me the song info on the screen for a few seconds before the backlight turns back off. Its nice because I can just prop the ash tray lid open and see the ipod screen perfectly from where I sit. Some of you taller folks might have to lean forward to see the bottom of the screen, but I guess being short pays off in this respect lol. When the lid is open it doesnt get in the way of my shifting arm too much. Normally when I'm shifting my arm is up and off of the console so this isnt a problem but while cruising and resting my hand on the shifter, my arm comes in contact with the open lid, again no big deal. Another nice thing about this is that when I leave the car, I just close the lid and voila, everything looks stock. Here are some pics. Comments and criticism welcome but keep in mind, its just a rough install. I plan on making some parts to make it look more like a factory install.
great install!
it was so simple I didnt think a write up was needed. I just routed the wires down through the center console, pulled out the ash tray and the lighting assembly, plug in the ipod and slid it in. It seems to want to sit like that naturally and doesnt want to move, like it was made for it. I'm going to have to do somthing about the wire though. Either put in some kind of retracting device or a cradle that slides in and out allowing me to use the controls on the ipod. Had a bit of trouble getting the ipod and all the wire back in while driving after changing genres last night. Still, not bad though. Trending Topics
it was so simple I didnt think a write up was needed. I just routed the wires down through the center console, pulled out the ash tray and the lighting assembly, plug in the ipod and slid it in. It seems to want to sit like that naturally and doesnt want to move, like it was made for it. I'm going to have to do somthing about the wire though. Either put in some kind of retracting device or a cradle that slides in and out allowing me to use the controls on the ipod. Had a bit of trouble getting the ipod and all the wire back in while driving after changing genres last night. Still, not bad though.But it does look good, good job.
its just hidden. Also, I was thinking it would be cool if you could fab something that made it pop up a little (pimp my ride style). Then you wouldnt have to take it out to change anything, but if it works through your steering wheel controls thats bad *** too.
This unit is nice but its not without its downfalls. If I made something that would raise/lower it like medwar11 suggests that would solve my complaints though. The prob I have with it is that if I decide to change genre or artist I have to use the ipod controls. After I pull the ipod out and change to whatever I want it gets a lil tricky putting it back in since I pull it out far enough to comfortably view its screen. Putting the foot or so of wire back in before the ipod, with only one hand takes skill lol. One idea that I've been messing around with and need to put more serious thought into is making an assembly that would allow the ipod to slide up and the ash tray lid to slide further down. This way when the ipod slides up it wont be at such a radical angle. Not sure if my fabrication skills are up for this challenge though. We'll see when I get some free time. My ipods one of the newer video ipods. I believe the converter works with a number of generations of ipods. Cant remember for sure which. You can search for it on google easily though. I had no trouble finding info on it.
