difference between coaxial and component speakers?
Old May 28, 2006 | 08:32 PM
themack56's Avatar
Exclamation difference between coaxial and component speakers?
difference between coaxial and component speakers? im about to buy a set of alpines but i was asked what i wanted coaxial or component speakers, i dont know the differnce aany one help me and explain to me whats the difference and whats the bes choice
Old May 28, 2006 | 09:04 PM
smokey1226's Avatar
coaxials have the tweeter already mounted inside of them. Meaning its set ontop of the speaker itself. The component speakers are a set of 2 tweeters, 2 crossovers, and 2 speakers. You then wire them up. Its a harder install because of the more wires to run but if your looking for a true SQ sounding setup then thats the way to go. Coaxials will get the job done but will sound nothing like a true comp setup. IF your lookign for great comp sets look at CDT audio. I had their cf61ef setup and it sounded amazing. Also you are going to need an amp (2 channel or 4 channel) to power a comp set to the needed wattage. The stock amp wont cut it.
Old May 28, 2006 | 09:27 PM
themack56's Avatar
cool thnx
Old May 29, 2006 | 06:52 AM
2MuchRiceMakesMeSick's Avatar
This is a component set which are a bit more involved with the install but can have better staging then a co-axial.
This is a co-axial. Typically cheaper and easier to install but not as good for imaging.
