Red-Light accenting my car
Old Jun 24, 2006 | 05:10 PM
contemptor's Avatar
Default Red-Light accenting my car
First of all, does anyone know where I can buy red bulbs to put in my rear view mirror and my dome light? I tried using some red plastic things that wrapped around the bulbs that autozone sold, but um... they started smoking after being on a few minutes, so that didn't work.
Also, I'd like to put something under the passenger and driver side, like down above the feet. The easiest thing I can think of is red neons, anyone have any suggestions what to buy? I want to wire whatever I get so that it only turns on when the doors open... where should I wire them to?
EDIT- Links to ebay auctinos or something for suggetions would be great
Old Jun 24, 2006 | 05:31 PM
01RedT/A's Avatar
get some cold cathode tubes. dirt cheap. as far as wiring them in, im not sure what controls the lights on the inside of the car, but i think its the body control module. ccfl lights draw a pretty low amount of amps, so they shouldnt damage anything, but be careful how you connect them.
Old Jun 24, 2006 | 05:33 PM
contemptor's Avatar
Small problem
I pretty much have no idea what I'm doing, and don't really know what you're talking about. I'm a car noob... pretty much why I posted here :o Sorry, I shoulda mentioned that.
Old Jun 24, 2006 | 05:54 PM
01RedT/A's Avatar
no prob. ccfl is cold cathode flourescent lighting, also know as instant igniting neon. it uses a filamentless bulb, and an inverter (takes 12v and turns it into around 600) do a search for ccfl on google, youll get thousands of results. some one else here could probably give you some pointers on how to connect it up properly to get your the results you want
Old Jun 24, 2006 | 06:00 PM
OOZ28's Avatar
I dunno about dome lights, but this is a pic with the lights in the floor board.
Old Jun 24, 2006 | 06:05 PM
contemptor's Avatar
Is that yours? That's exactly what I want, except I want it wired (if possible) so it turns off when I shut the door.
Old Jun 24, 2006 | 06:15 PM
OOZ28's Avatar
yea its mine, I have it wired up to its own switch so I can have on when I want, as far as wiring it up to come on when the door opens, Id try finding a 12v wire running to the dome lights and use that for your power, jmo though.
Old Jun 24, 2006 | 06:18 PM
contemptor's Avatar
Where/what kind of lights are you running? link perhaps?
Old Jun 24, 2006 | 06:25 PM
OOZ28's Avatar
Heres the link to the ones I used, I got them from Advanced Auto. They are the 15' Red ones
http://www.partsamerica.com/ProductD...tnumber=OP15RD
Old Jun 24, 2006 | 06:38 PM
WhiteStripes's Avatar
I have the same thing... only blue. I also have smaller ones in all the A/C vents. I'll post pics up tonight. I too have mine wired to a switch though so I can control them. I know that my Autozone has a little end-cap that sells a ton of different colored bulbs. I did my domelight, reverse lights and side marker lights in blue, but decided against doing the ones in the mirror blue as I need some plain light for reading stuff.
Old Jun 24, 2006 | 10:07 PM
contemptor's Avatar
15 feet, that's pretty long :o
You don't have any trouble with them overheating, or accidentally kicking them or anything?
Old Jun 24, 2006 | 10:12 PM
contemptor's Avatar
End-cap? You mean little plastic sleeve like deals to go over the lights?
I tried that with rear view mirror lights, and my dome light, because didn't sell red ones like that. Today after the door was open for a few mins my rear view one (only did one to test it) it started smoking... it seems that bulb gets way too hot. I thought I saw some smoke coming from the rear bulb also, and the bulb/plastic was REALLY hot so I took it out too :/
I wish I could find red bulbs to fit the rear view and dome.
And how did you get the ones in the AC vents wired? Do you have wires running out of your vents?
Old Jun 25, 2006 | 09:52 AM
WhiteBird00's Avatar
Ungrounded Moderator
An "end cap" is a retailing term refering to the shelving at the end of an aisle that's used to promote products with added visibility.
You can find red bulbs online at places such as autolumination.com. The mirror uses #214-2 and the dome light uses #561. You can Google using "bulb red 561" (without the quotes) to find other suppliers.
Old Jun 25, 2006 | 11:34 AM
KillerKlown's Avatar
Thats looks coooool!
Old Jun 25, 2006 | 12:27 PM
contemptor's Avatar
Thanks a ton. Autozone didn't have those sizes in color- I'll grab them online.
Edit- 6.99 a bulb at autolumination... ouch
Old Jun 25, 2006 | 09:37 PM
bad6as's Avatar
i have some in white.
they come on and turn off with the map and dome lights
under the a piller their are 3 wires that go to the map light tap in to their and run the wires and your done.
Old Jun 26, 2006 | 05:39 PM
OOZ28's Avatar
They dont make any kind of heat, and they tucked up real nice so kicking isnt really a big issue.
Old Jun 27, 2006 | 09:05 AM
contemptor's Avatar
Thanks a ton man, that's what I'm going to do. Hate to sound stupid, but how do I get under the A pillar.
Old Jun 27, 2006 | 02:25 PM
4ced's Avatar
ill be getting some soon for my audio set and under the dash
Old Jun 27, 2006 | 03:06 PM
Duffster's Avatar
I'm not sure. . .but I believe 00Z28 meant 15" or inches. . .never seen a 15 foot red light.
