Red-Light accenting my car
Originally Posted by contemptor
Thanks a ton man, that's what I'm going to do. Hate to sound stupid, but how do I get under the A pillar.
Originally Posted by WhiteBird00
If you don't have t-tops then just open the door and pull the trim panel away from the A pillar - it's held on with clips. If you have t-tops you will have to remove them and take out the two screws at the top of the pillar trim before you can pull it off.
http://autolumination.com/ good site for bulbs ...... festoon bulbs for dome and map lights and 74 for hvac and headlight switch and 194 for dash .... been there ... done that ... red exterior and interior
CCFL in floor soon and also leds in vents
I jsut got my map lights from advance auto parts it's bulb number 211-2 red. The are a little different than the 212-2 but work perfectly. I am still trying to find a red dome light and it looks kinda crappy with a white dome. so if anyone can tell me the number of the dome and maybe where to get a red one that would be awsome!
You can find red bulbs online at places such as autolumination.com. The mirror uses #214-2 and the dome light uses #561. You can Google using "bulb red 561" (without the quotes) to find other suppliers.
First of all, does anyone know where I can buy red bulbs to put in my rear view mirror and my dome light? I tried using some red plastic things that wrapped around the bulbs that autozone sold, but um... they started smoking after being on a few minutes, so that didn't work.
Also, I'd like to put something under the passenger and driver side, like down above the feet. The easiest thing I can think of is red neons, anyone have any suggestions what to buy? I want to wire whatever I get so that it only turns on when the doors open... where should I wire them to?
EDIT- Links to ebay auctinos or something for suggetions would be great
OInly thing is that neon lights don't like the cold and you can't dim them if they bother you at night when you're driving...
I'd suggest looking for a LED light strip. way less power consumption, very little heat at all, cold weather frendly and they'll take a few more kicks when stuck under the dash than ANY neon.
Just my two cents
#32
Originally Posted by Rede
I'm kind of surprised that no one's thought of this, but goto a computer store and pickup a 10 or 10" red neon light for 10 bucks. They're 12v so no problems there.
Just my two cents
Just my two cents
#33
i suggest LED bulbs for the dome light and map lights. if your camaro is 2000+ then i think your map light bulbs are 194, at lest mine were in my 01. i wasnted super white (like what the new caddys have) and so i did that. check ebay for "red led 194" or plug in the bulb number for the other one. itll lok way better, no heat, last forever, and the color wont fade.
#34
Originally Posted by FireSilverLullaby
Yeah i got some red cathode tubes from a computer supply store online. And i have red dome lights.
Does anyone know if its illegal to have red light, cause I heard it was but im not sure.
#35
Ledgauges.com has LED map and dome setups in red. I got a set from Nate about a year ago. They work great, and hes a sponsor.
The footwell lights are sweet. Did you say those dim like the rest of the interior lights when you open/close the door?
