Power Door Lock Issues
Old Jun 25, 2006 | 06:36 PM
ZROCWS6's Avatar
Default Power Door Lock Issues
Hey everyone. I just picked up a 99 WS6 and have an issue. The power door locks will not lock when pushing the door buttons or on the key fob. They do unlock just fine however. I can manualy lock them and unlock with the power functions. I can here a clicking noise like the relay is clicking but not the door lock actuators moving like when I hit the unlock button. Would this be just a control module issue or somehthing more? I read the owner's manual about how you can set the door locks and all that to your liking and it did not do anything. I also hear a beeping noise when push the lock button.
Old Jun 26, 2006 | 08:48 AM
ZROCWS6's Avatar
Anyone?
Old Jun 27, 2006 | 09:52 PM
Hugger Z's Avatar
Mine started doing something similar just before they went crazy as I stated in my post (https://ls1tech.com/forums/showthread.php?t=532171). I have disconnected the switch to see if there might have been a bad connection. If this does not help, the BCM is next on my list to find and check. It could be your BCM. It sounds like it is beeping the horn but just not sending the signal to lock the doors.
Old Jul 1, 2006 | 09:03 AM
ZROCWS6's Avatar
Ok I have done a bit of checking in the little time I have, anyway, I have power at the switch and continuity through the switch both driver and passenger. The door lock actuator works as it will unlock the doors. Now the haynes manual said there is a door lock relay but in the wiring diagrams it doesnt show one. Is there one? I can hear a clicking noise like a relay. Is it in the BCM? I also hear a dinging noise when the lock button is pushed. Also when I use the key fob to lock the doors outside of the car it honks and flashes the lights arming the system but the door doesnt lock, obviously, and when you open the door the alarm starts goin off. This is making me believe its the BCM. The previous owner said he never had a problem and it started the day I got it.
Old Jul 1, 2006 | 10:41 AM
WhiteBird00's Avatar
Ungrounded Moderator
There is no relay for the door locks - it's all controlled by the BCM. It almost sounds like the "prevent lockout" feature is malfunctioning. There is a programmable feature in the BCM that prevents the doors from locking if the key is in the ignition. It's possible that there is something wrong that makes the BCM think the key is always in the ignition. Try programming that feature off (instructions are in the owner's manual) and see if that solves the problem - then be very careful not to lock your keys in your car.
Old Jul 3, 2006 | 09:05 AM
ZROCWS6's Avatar
I havnt tried to repgrogram that off but I have found that the red/blk wire has continutity from the BCM to the both door lock switches but not to ground. I will try to reprogram the locks off the lock out and see if that works otherwise it looks to be a new BCM for me.
