help
Old Jun 26, 2006 | 05:19 PM
junior83's Avatar
Question help
My ws6 has a stock alarm, but I do not have the control. I have noticed that when I lock the doors from the driver's side it does not get armed but when i lock the doors from the passenger side it does get armed. If I open the car from the left side the alarm will not go off but it does if I open the passenger side first. When I get off the car the stereo does not turn off, but if the passenger door is opened the stereo does turn off and the same thing happens with the interior lighting. Is a fuse burned or maybe a wire is disconnected? Everything works fine with the passenger side but not on the driver's side. Would appreciate the help thanks.
Old Jun 26, 2006 | 07:16 PM
VIP1's Avatar
Copy & Paste Moderator
If I remember correctly, the switch is built into the door latch. Either the switch broke or a wire going to it broke.
Old Jun 27, 2006 | 07:11 AM
WhiteBird00's Avatar
Ungrounded Moderator
VIP1 is correct - the switch is in the door latch. There is a certain amount of adjustment available in the latch/switch assembly so it might just need to be aligned properly. Also, they can get badly gummed up with road grime so it wouldn't hurt to try cleaning it before spending the money on a replacement.
If I open the car from the right side the alarm will not go off but it does if I open the passenger side first.
BTW, the right side is the passenger side. Left and right are always determined from the driver's seat.
