How to wrap plastic panels in vinyl???
1- sand the plastic with 80 grit, get it good and rough
2- thourougly clean the plastic of all oils. SEM makes a cleaner specially for this.
3- spray the plastic with adheasion promoter
4- spray high build polyester primer
that will give you a good surface for your glue to stick to. But forget about any rattle can 3m stuff, you need to use auto grade contact cement. Landau top adheasive specifially works great.
mike
