Need help locating signal light flasher
Old Jul 3, 2006 | 08:15 PM
m1candelaa1's Avatar
Default Need help locating signal light flasher
I have a 99 trans am. Im having problem locating the flasher for my signal lights. Any help would be appreciated.
Old Jul 3, 2006 | 08:38 PM
Anyone
Old Jul 3, 2006 | 09:37 PM
Need help badly ASAP!!! PLZ!!!
Help Needed!!!
Old Jul 3, 2006 | 09:44 PM
99T/A's Avatar
Pull the panel under the dash loose. There are 2 flashers (1 for turn signals and 1 for hazard flashers). They should be located on either side of the steering column. If only one of them is there then check under the dash up in behind the radio, A/C panel.
Old Jul 4, 2006 | 11:37 AM
Thanks I found the one closest the the door . Ill look for the other behind radio AC panel...
