XM radio and monsoon
Old Jul 7, 2006 | 02:45 PM
98BPMTA's Avatar
Default XM radio and monsoon
is there some kind of plug i can get to put XM in the monsoon. useing the AUX or CD changer
i hear it goes in were the CD changer plugs in the head unit. seeing i dont use my CD changer this would be a cleaner sound insted of the FM modulator.
has anybody done this?
Old Jul 7, 2006 | 03:32 PM
PLOEG's Avatar
Yea I'm Wondering The Samething
Old Jul 7, 2006 | 04:19 PM
Ubergeist's Avatar
Not really, I had sirius in my T/A when I bought it.
I don't really listen to the radio, and with 13 CD's to choose from at will, I didn't see a need for it. So I got it professionaly removed.
I am selling the complete kit if you guys would be interested. Comes with everything. PM if you are.
Old Jul 7, 2006 | 09:17 PM
WhiteBird00's Avatar
Ungrounded Moderator
With a 2000 or newer CD head unit or any year cassette head unit you can use an adapter such as the GM9-AUX to provide RCA auxiliary input through the radio's CD changer port. Then you just get a 1/8" miniature stereo (headphone) plug to dual RCA cable so you can plug the satellite radio into the adapter.
Old Jul 7, 2006 | 11:24 PM
VIP1's Avatar
Copy & Paste Moderator
http://www.fadingarrow.com/XMSatelliteRadio.htm
Old Jul 8, 2006 | 06:54 AM
98BPMTA's Avatar
Just what i was looking for............ BIG Thanks.
Old Jul 8, 2006 | 08:10 AM
Roadhouse's Avatar
I like where the XM antenna was put.
Old Jul 8, 2006 | 09:47 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
I used the PIE X3GM12 with X3 Brain Module
Link and pic below:
http://www.myradiostore.us/auxadapte...er/x3gm12.html
Old Jul 9, 2006 | 05:11 AM
pontiacguy84's Avatar
What if you have a 1999 or older head unit? And if it can't be done with older h/u's can you put a 2000+ h/u in a 99 f-body?
Old Jul 9, 2006 | 12:55 PM
The actual changeover was made in the middle of the 99 model year but I usually say 2000 or newer because it's very difficult to tell if a 99 is the early or late model. This only applies to CD head units - all years of cassette head units will work.
Yes, you can put a newer head unit in your 99. The changes on the newer models were completely internal so a newer one will mount and plug in exactly the same as the original. If you've decided to use the GM9-AUX adapter and are willing to buy a newer HU to make it work then I would try it with your existing HU. If you happen to have the later 99 model then it will work without buying anything else. But if it doesn't work then you haven't lost anything except time - you can then buy a newer HU to make the adapter work.
Old Jul 9, 2006 | 08:48 PM
98BPMTA's Avatar
i bought this first http://images.jr.com/productimages/E...FFFFF&CVT=jpeg
BUT the FM antenna plugs are too big, were it goes between the head unit and the outside FM antenna.
Old Jul 9, 2006 | 11:52 PM
VIP1's Avatar
Thanks. Glad I could be of help
The connection in the rear where the stock antenna meets the extension wire that leads to the front is the same as the aftermarket.
