Monsoon Head Unit to Alpine CDA-9851
This may sound like a dumb question, but will this aftermarket head unit be better than my factory monsoon head unit? I've heard before that the monsoon head units have an internal amplifier needed to supply the power to the speakers, but will the alipine head unit be an overall better head unit?
I would also rather get the alpine 9856 for IPOD fullspeed alone.
basicaly dissconnect your amp, and run new wires from the speakers to the deck. Make sure you run atleast a 16gauge incase you deside to amp them later on.
The thing that causes more problems is the filtering done by the amp. The sail panel speakers only get low frequency signal from the amp so there isn't much point in putting full-range (coax, 3-way, etc.) speakers there unless you rewire them directly to the head unit. On the other hand, some good aftermarket 6.5S subs or mid-bass speakers mounted there can sound pretty good.
I know in my WS6, the sailpanel subs are definitely 4ohm+4ohm DVC... and I've read on the Houston F-Body Monsoon wiring website that the front components and hatch components are 4 ohm in all Firebirds..
Firebird coupes have ten speaker elements. The doors have 6.5S (oversize) mid-range speakers running at 2-ohms off the amp and .75" tweeters running at 4-ohms off the head unit. The sail panels have 6.5S dual voice coil 4-ohm subs wired in parallel to produce a 2-ohm load for the amp. The hatch has 4" mid-range speakers running at 4-ohms off the amp and .75" tweeters running at 4-ohms off the head unit.
Camaro coupes have eight speaker elements and they all run off the amp. The doors have 2-ohm 6.5S mids and 4-ohm tweeters mounted coaxially but wired as components. The sail panels have 6.5S subs running at 2-ohms and the hatch has 4" extended range speakers running at 4-ohms.
Convertibles are wired similarly to Camaro coupes (all speakers run off the amp) but the speakers are physically different of course.
