where is the running light box?
Old Jul 15, 2006 | 08:47 PM
just1news6's Avatar
Default where is the running light box?
i think i have a short and its around the running light box. i keep burning up the dashboard light fuse someone please help!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 16, 2006 | 10:22 AM
WhiteBird00's Avatar
Ungrounded Moderator
What do you mean by the "running light box"? There is a Daytime Running Light (DRL) module mounted behind the radio but it has nothing to do with dash lights. The dash lights are controlled by the instrument panel dimmer switch through the IP DIMMER fuse (#16). The dimmer switch gets power through the headlight switch from the PARK LPS fuse (#5) which also powers the DRL module. However, the IP DIMMER fuse is downstream from the module and the switches so there is nothing between the fuse and the dash bulbs. If that's the fuse that is blowing then you must have a short someplace in the wiring to the bulbs.
