interior lights wont turn off
Old Jul 16, 2006 | 09:20 PM
FireSilverLullaby's Avatar
Default interior lights wont turn off
My interior lights wont turn off, all the doors are shut and the car is locked, and they been on for a few hours. It says security in the guages while the car is off, im not sure if it was always like that.
I replaced the lights with led lights a few months ago, will these run down a battery if their on over night or do they not take up much power.
Old Jul 16, 2006 | 09:27 PM
brock417's Avatar
you may want to check the roller switch by the your headlight switch and make sure that its not turned on (not all the way up).
Old Jul 16, 2006 | 09:35 PM
it was and i turned it all the way down, but doesnt that only control the instrument pannel, and the interior lights are still on.
My back dome lights just went out could they of just gotten to hot and burned out, but the front ones are still on.
Old Jul 16, 2006 | 10:16 PM
Alright when i try to push the door lock button on the inside it beeps like when you leave your lights on. So something is open or somethin.
I have checked all doors and lights can someone give some more things to check, that would cause the interior lights to stay on and the car to beep when i lock the doors.
thanks
Old Jul 17, 2006 | 02:24 AM
02Z28LS1's Avatar
the only things that i think it could even be are one of the doors/hatch are open, the roller switch is on all the way, or the buttons underneath the rearview mirror are turned on
Old Jul 17, 2006 | 08:24 AM
todddchi's Avatar
Could there be problems in your column switch? Like it is sensing there is still a key in it?
Old Jul 17, 2006 | 12:27 PM
Well only my front lights were on and i just had to take the bulbs out, and i dont think its sensing the keys are still in cause it doesnt beep constantly only when i push the lock door button on the inside.
Some sensor or something must be wrong.
Old Jul 17, 2006 | 01:33 PM
Camaroz's Avatar
Try pushing in the little tabs that sense if the door is opened or not. where the latch is and see if the interior lights turn off when you push in a certain one. if it does you've probaly found the problem door/hatch..
Old Jul 20, 2006 | 10:15 PM
brock417's Avatar
mine started the same thing yesturday and i messed with my driver side door and it acted like it didnt want to close all the way.. i slammed the door close a few times and i looked in a little later and they had gone off..
Old Jul 25, 2006 | 11:32 AM
well my lights turn off now, not sure what caused it.
Old Jul 25, 2006 | 12:47 PM
kraaazymike's Avatar
I have the same problem with my car. Then the problem randomly went away for a month and now the lights wont turn off again. I just disconnected my lights, it drove me nuts to drive around at night with these lights on all the time.
