do i got this right?
Old Aug 8, 2006 | 01:31 PM
b's90cam's Avatar
Default do i got this right?
Just got done reading the ohm tech article and now im confused. My plans are for 2 type s 10 with an alpine mrp m650 amp. Specs for the speakers are dual two ohm voice coils and a 300 rms max. The amp is a monoblock 600 watt rms. I plan on running the voice coils in series and the speakers themselves in parallel to the amp. This will produce a 2 ohm load bridged at the amp correct?
2 ohm voice coils in parallel create a 4ohm load
2 4 ohm load bridged make a 2 ohm load.
Old Aug 8, 2006 | 01:41 PM
MikeFbody's Avatar
Restricted User
first, with a mono amp, there is no bridging.
2 ohm coils in parralel create a 1 ohm load.
2 ohm coils in series create a 4 ohm load
2 4 ohm loads in parralel create a 2 ohm final load
2 4 ohm loads in series create a 8 ohm final load
to get a final 2 ohm load, series the 2 ohm coils on each sub, and parralel each sub with each other to the amp.
mike
Old Aug 8, 2006 | 02:30 PM
b's90cam's Avatar
Thanks for setting me straight.
Old Aug 8, 2006 | 02:37 PM
b's90cam's Avatar
so for a dual 4 ohm single speaker would be to wire both in parallel to create a final load of 2 ohms right.
Old Aug 9, 2006 | 07:03 AM
MikeFbody's Avatar
Restricted User
correct
