some ohm issues
Old Aug 11, 2006 | 11:46 AM
00cls1camaross's Avatar
Default some ohm issues
alpine mrp-m450 amplifier mono
10" type r 2 ohms
how to i wire it with the bannana plugs to keep it at 2 ohms or if i dont use them how do i connect it so that it will run 2 ohms
thanks
btw alpine type r is dual voice coil
Old Aug 11, 2006 | 12:00 PM
Blacker's Avatar
Those speakers come in either dual 2 ohm (SWR-1022D) or dual 4 ohm (SWR-1042D) versions. If you are using one speaker, it is not possible to have a final load of 2 ohms with the SWR-1022D. You would have to have the dual 4 Ohm version to do that. The only options for the SWR-1022D is 1 ohm or 4 ohm.
Old Aug 11, 2006 | 12:24 PM
jimmy 2 Times's Avatar
blacker is correct, you can only get 2ohm load (with 1 sub) if you have the dual 4ohm version of the sub
Old Aug 11, 2006 | 12:39 PM
damn... is it not going to sound very good since with 4 ohms i get almost half power out of my amp?
or if i wire it 1 ohm will i kill my amp? or sub?
Old Aug 11, 2006 | 02:01 PM
is your amp 1ohm stable?
what amp do you have?
Old Aug 11, 2006 | 02:03 PM
http://www.alpine-usa.com/en/product...model=MRP-M450
Old Aug 11, 2006 | 02:50 PM
Blacker's Avatar
The Alpine MRP-M450 is not 1 ohm stable. Sounds like you need to get the dual 4 ohm version to get what you want. The dual 2 ohm versions are good when you use 2 of them, like I am doing. That gives you a final load of 2 ohms.
