What is a "switched" 12 V source....
Old May 23, 2002 | 10:09 PM
BLUEBYU's Avatar
Default What is a "switched" 12 V source....
I have been adding a lot of add'l electrical to the car...bottle openers, heaters, purge..etc. and I have been connecting them to the power terminal on driver's side next to the fuse boxes.
Is this the correct way? Is this a "switched" source.?
Thanks for the help.
Old May 23, 2002 | 10:16 PM
cantdrv65's Avatar
Default Re: What is a "switched" 12 V source....
A switched source means turned on and off by the ignition key. The Accessory terminal in the fuse box is a switched source. If you use a nonswitched source for electrical components your battery could go dead upon sitting for a few days.....Use a testlight or VOM and turn the key on and off. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ May 23, 2002, 10:18 PM: Message edited by: cantdrv65 ]</small>
Old May 24, 2002 | 11:02 PM
BLUEBYU's Avatar
I don't think the terminal next to the fuse box is switched. It looks to me to be just an extension of the battery terminal. Now that I have wired everything to this point, I really do not want to run everything back to an ignition fuse. Can I simply spice in a switch on the battery lead to the terminal. I would just remember to turn-off the switch if I am going to let her set awhile. Any electrical guys out there have a good suggestion?
Old May 24, 2002 | 11:40 PM
horist's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BLUEBYU:
<strong>I don't think the terminal next to the fuse box is switched. It looks to me to be just an extension of the battery terminal. Now that I have wired everything to this point, I really do not want to run everything back to an ignition fuse. Can I simply spice in a switch on the battery lead to the terminal. I would just remember to turn-off the switch if I am going to let her set awhile. Any electrical guys out there have a good suggestion?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">U are correct, the lead by the fuse boxes is constant 12V. I spliced directly into the ignition wire for all of my switched needs... if you take the panel off on the drivers side above the pedals, there is a big Pink wire (thick), I just stripped away some of the rubber insulation, soldered the wires in, and taped it up... haven't had a problem
Old May 25, 2002 | 12:11 AM
BLUEBYU's Avatar
Thanks for the info. My battery is running dead after a few days though, but I have all power leads running to the fuse box terminal. Any ideas? I have recently replaced the battery.
Thanks again.
