Express Down Window?
Old May 29, 2002 | 03:05 PM
BEASST99's Avatar
Default Express Down Window?
How do you make the passenger window express down??
Thanks
Old May 30, 2002 | 10:10 AM
alexWS6's Avatar
Default Re: Express Down Window?
i would like to know that as well...
anyone?
Old May 30, 2002 | 08:36 PM
99 WS6's Avatar
That would be cool!
Old Jun 3, 2002 | 06:46 PM
The Dragon's Avatar
I want down and up for both sides.
Old Jun 3, 2002 | 07:26 PM
Johnny's Avatar
Just go to any car stereo or alarm shop that sells D.E.I. products (viper, sidewinder, python, hornet, ect.) and ask them about a 530t window automation module. They are usually used with a alarm but you can install it by itself to just do the window automation and it will control both windows up and down. At my shop we sell them for around $150 installed and I know that's a pretty common price in my town.
Old Jun 4, 2002 | 05:46 PM
chev4life's Avatar
Can you explain in more depth how the modual works....does it work off the stock switches??? Do you happen to have any part numbers that would get the job done?
Old Jun 4, 2002 | 06:36 PM
BEASST99's Avatar
yes it would be great if you would explain the specifics.
Old Jun 4, 2002 | 09:14 PM
The Dragon's Avatar
Dittoing the above 2.
Old Jun 4, 2002 | 11:25 PM
Z-Rated's Avatar
I bet there is a way to ghetto it, that i mean, splice a wire into the pass side whenever the express is hit. I think i saw it some where, ill take my door apart tomm.... guess we will see
Drew
Old Jun 5, 2002 | 04:39 PM
Johnny's Avatar
The model number is 530T it is sold by D.E.I.. Anyone that sells Viper, Sidewinder, Python, or Automate should have that piece in stock or be able to order it for you. It fully automates the windows in both the up and down directions all you have to do is tap the button in the direction you want it to go and if you wanna stop somewhere in the middle just tap it again. Also if you later hook up a alarm it can roll your windows up everytime you arm the alarm or roll them down if you want whenever you hit a extra channel on the alarm. Hell if you want you can have them wire it up where it will roll the windows up everytime you turn the ignition off but that might get annoying. Plus it has built in limiter feature so if your hand is in the way it will stop so you don't have to worry about a kid hurting himself. All in all it's a pretty nice piece i've used it on several of my own cars without a problem.
Old Jun 5, 2002 | 04:42 PM
Johnny's Avatar
Oh yea i forgot to meantion it does work with all the factory wires and switches so it won't booger anything up. Just requires a lil spliceing on the factory wires on the driverside.
Old Jun 8, 2002 | 12:56 AM
jkayner's Avatar
there is a member on camzroz28.com that has done this mod and only cost around $25 his name is brent Franker. Do a search and you'll find it.
**edit** okay i saved some time, here is the link. http://www.bfranker.badz28.com/fbody/expresswindow.htm
<small>[ June 07, 2002, 01:02 PM: Message edited by: jkayner ]</small>
