aftermarket headunit question
Old Jun 27, 2002 | 03:46 PM
alexWS6's Avatar
Default aftermarket headunit question
im looking to purchase the alpine IVA-C801 (if you guys are familar with it), and i've looked at two stores so far. both salesmen have told me that i will need to replace the speakers if i get it, they said something about ohms on the monsoon systems not matching the alpines <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> , cant remember the specifics. i'd probly upgrade the speakers in the future anyway but i was just wondering if this is bs or not. thanks
<small>[ June 27, 2002, 03:48 PM: Message edited by: alexWS6 ]</small>
Old Jun 28, 2002 | 12:49 AM
Kevin's Avatar
Default Re: aftermarket headunit question
If your doing just the headunit then you are fine. Install it as you would a regular headunit. Its when you get into swapping out the amp you'd want to do speakers.
Kevin
Old Jun 28, 2002 | 01:16 PM
LIL SS's Avatar
Moderator
You also may run into a small problem with the front tweeters as they are power off the stock receiver with out going through the monsoon amp..
Old Jun 28, 2002 | 01:47 PM
alexWS6's Avatar
alright. thanks
Old Jun 28, 2002 | 08:40 PM
slow's Avatar
tweeters, and all work fine, the monsoon just has one connection and thats the same 1990+ GM white connector. You can put almost any Delco deck in place of it, or any deck wired for a GM car
Ryan.
