Sub and Amp wiring ?
Old Aug 16, 2006 | 08:03 PM
Blk00TransAm's Avatar
Default Sub and Amp wiring ?
Can some one give me a deailed diagram of how to do this ? i have no idea and am starting from scratch. I have no idea how to get power to the rear hatch. and after i do get it there i have no idea how to disperce it to the amp or subs. how do i hook the subs to the amp ?
Old Aug 16, 2006 | 08:33 PM
Black01M6SS's Avatar
http://www.crutchfieldadvisor.com/S-...ps.html?page=2
Can you give me the model number of the amp and subs that your trying to install?
Old Aug 16, 2006 | 08:39 PM
I Dont have the model numbers bbut it is an untralinear 1600 watt amp and two Audio pipe 10" subs if that helps
Old Aug 16, 2006 | 09:09 PM
Nah, I need to know how many channels the amp is and how much power in RMS it puts out at what OHM load. Hopefully it will have a tag on the bottom or something on it that says something like.
200rms x2@4 ohms
400rms x2@2 ohms
800rms x1@4 ohms bridge
That would be an example of most "1600 watt" 2 channel amps.
Also I need to know what the ohm load of the subs are and if they are duel voice coil or single. They should say on them somewhere something like 4 ohm DVC. The "ohm" symbol looks kinda like a "U".
