FS JL 300.2 amp NEW!!! and NEVER installed!!
Specifications:
Rated Power (stereo):
150 W RMS x 2 @ 1.5 ohm-4 ohm
(11V-14.5V)
Rated Power (bridged):
300 W RMS x 1 @ 3 ohm-8 ohm
(11V-14.5V)
THD at Rated Power:
<0.03% @ 4 ohm
S/N Ratio*:
>108.5 dB below rated power
Frequency Response:
5 Hz-30 KHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm per ch./50 Hz
Input Range:
switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions:
13.4"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology:
(1 pair of inputs)
On-board Crossover:
fully-variable (50 Hz-5 KHz),
selectable-slope LP or HP (12 or 24 dB per octave)
Preamp Output:
2-channel (full-range, LP or HP)
Speaker output connections:
accept up to 8ga. wire
+12V and Ground connections:
accept up to 4ga. Wire
I believe the amp retails for $399!!! You can find it for close on EBAY but you have to worry about more on there. I have been on the LS1 boards for 3 years and sold alot of stuff <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Let me know if you have any other ?s
bob
(11V-14.5V)
(11V-14.5V)
THD at Rated Power:
<0.03% @ 4 ohm
S/N Ratio*:
Frequency Response:
Damping Factor:
Input Range:
to 800mV-8V RMS
Dimensions:
Features:
(1 pair of inputs)
On-board Crossover:
Preamp Output:
bob
