headlights high-beam flash-to-pass
Dave
https://ls1tech.com/ubb/ultimatebb.p...;f=29;t=000224
Just thought I would chime in and let you know my old 4 beam brights and fogs with brights mods are up and running on my website.
It's still a work in progress, but at least it's in a new spot. Our cable company dumped Road Runner thus the change in websites.
Check out my mods page Here
At this time only the two above mods are up and I'm working on a few others.
Hope this helps! <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
<small>[ September 24, 2002, 02:35 AM: Message edited by: Zurbo ]</small>
Yep, my mod requires you cut 2 factory wires like you say in your link, but at least you can turn the fogs on and off at will! <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Dave
--VIP1
- pulling back on the stalk to turn on your highbeams, then letting go on the stalk to turn them off.
- The highbeams will come on irregardless if the headlights are on.
- pulling back on the stalk will only keep the lights on while the stalk is pulled back. It is a single action.
I think what you are describing is pulling the stalk back twice, once to turn them on and again to turn them off. That is not what I wanted. Thanks anyway though for the reply.
I gather then the problem with the mod is that the factory stalk is a on/off switch instead of a momentary contact..
I heard that in order to do that the WHOLE stalk has to be changed (I am not really sure about this I just heard about it once). One of the reasons were because of:
1) You know that clicking sound you hear when activating the brights? that has like a little clip or something that holds it in place and that has to be modified.
2) The whole stalk has to be changed because it was made to click just like the way it comes. And if you decide to change that, you will have to put a new stalk that was made to work like the one you desire "flash-to-pass"
Again Im not sure about this... this might give you a better picture on what your dealing with though.
Also dont forget that the way it comes stock is safer on the bulbs. This is because when you flash to pass you will pull the stalk not all the way through sometimes and that does result in shooting High volts to the brights with sudden high power which could cause the bulb to wear out if done excessively. However with it stock, that high shot of volts is controlled by a simple switch.
If anyone has more detailed info on how to do this or to correct my understanding of doing this mod please tell me about it and ill be glad you did.
