Stock AMP location?
Old Sep 27, 2002 | 10:42 AM
RUF SS's Avatar
Default Stock AMP location?
Where is the stock monsoon amp located in a 98 SS?
Thanks for the help!
Old Sep 27, 2002 | 01:41 PM
RUF SS's Avatar
Default Re: Stock AMP location?
Thanks!
I will check it out!
Old Sep 27, 2002 | 02:43 PM
RUF SS's Avatar
It is not there!
Anyone else knows where it is?
Old Sep 27, 2002 | 03:03 PM
KeithSS's Avatar
It is mounted backwards on a piece of metal above the wheelwell in the spare tire compartment. It is black and has one big plug on the opposit side of what you can see. If you follow the antenna cable towards the front of the car you will see the amp on the backside of that metal bracket as you get close to to top of the wheelwell. If you have any problem finding it let me know. I run a car stereo shop.
Keith
Old Sep 28, 2002 | 12:09 AM
JLMoses's Avatar
I believe that in all the 98+ f bodies that the Monsoon amp is located in the rear spare tire area. Take the cover off the spare tire out and it is a black box approximately 5x7 in size. It's in the top portion of the spare tire well. Good luck and I hope I helped you out. That's where it is in the 99 T/a and the 2001 Z-28 at least. good luck. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Sep 30, 2002 | 12:17 AM
RUF SS's Avatar
Thanks!
I will check it now!
Old Mar 17, 2005 | 12:05 PM
gnxturbo87's Avatar
I can't find where the amp is or was. I just bought the car and all the wires are cut and capped. None of my speakers will play. The radio will come on though.
Old Mar 17, 2005 | 03:27 PM
2MuchRiceMakesMeSick's Avatar
Well I think you answered all your questions right there
Old Mar 20, 2005 | 01:54 PM
SStheBest's Avatar
dooouuughhhh .....lmao
Old Mar 20, 2005 | 02:08 PM
Phoenix 5.7's Avatar
spare tire well, as the others have said. its junk anyway, so don't worry about not having it
