A4 gear indicator light
Old Oct 12, 2002 | 02:38 PM
SuperSound99SS's Avatar
Default A4 gear indicator light
My gear indicator light has gone out on my 99. Whats the best way to change and what kind of bulb does it take? Thx guys
Old Oct 13, 2002 | 06:08 PM
WEASEL's Avatar
Default Re: A4 gear indicator light
Don't know what bulb it is but......put the car in neutral (not cranked). You need something like needle-nose pliers to pull out a metal clip on the front side of the shift ****.
Pull the **** off, don't lose the clip. Then pop out the tray or TC switch panel that's in front of the shift ****. You may have to unplug the connections.
Other than that, I think there's only 2 screws/bolts to remove. Open up the armrest and they should be there at the front. If you have a coin holder, pull it straight up and they're under there.
What a pain, huh? Hope that helps. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Oct 13, 2002 | 08:27 PM
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> thx man...i'll be trying it tomorrow
