Installing amp. Before or after stock Amp?
Old Oct 27, 2002 | 07:50 AM
1BadAzzHawk's Avatar
Default Installing amp. Before or after stock Amp?
Ive installed two 12" subs and now have to wire in the amp. Since theres no RCA plug on the stock system, Im getting a Covnerter. Do I install it before or after the stock amplifier?
Old Oct 27, 2002 | 04:51 PM
RTCamaroSS's Avatar
Default Re: Installing amp. Before or after stock Amp?
Mine is installed before the amp, actually in the rear of the deck.
Old Nov 3, 2002 | 08:43 AM
Big Gulp Johnson's Avatar
ttt....I need to know also. Do I NEED to install behind the HU, or can I do it off a rear speaker. Should I splice into the wires going to the middle subs, or from the rear speakers? Thanks!!
Ken <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Nov 4, 2002 | 03:28 PM
02Z's Avatar
02Z
I just installed a sub amp last weekend. I used the rear left and right speaker inputs to the Monsoon amp. My sub amp had high-level inputs, it also had input sense so I didn’t have to run a remote. Sounds great with the stock stereo, I just need a remote crossover control to tune it.
Hope this helps! Good Luck!!
Old Nov 4, 2002 | 06:16 PM
I've replaced an Ls1 motor, did a heads and cam swap, and all the bolt-ons...but I have no idea where the monsoon amp is <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Can someone clue me in...thanks!!!!
Old Nov 5, 2002 | 05:12 AM
Beeler422's Avatar
Back in the staging lane
It's in the back passenger side of the car under the plastic panel where the rear speaker and spare tire are.
Old Nov 5, 2002 | 07:35 AM
02Z's Avatar
02Z
One of the great people on this board gave me this link when I was wiring my amp. The colors of the wires did not match mine (maybe because I have a vert) but the pin out was correct. I didn't find any DC at all on the inputs (maybe millivolts). Now that i have a sub, I got the bug, I want a head unit now! No, I better save for those headers... Good luck!
http://www.houston-f-body.org/tech/m.../AmpCamaro.htm
<small>[ November 05, 2002, 07:37 AM: Message edited by: 02Z ]</small>
Old Nov 5, 2002 | 08:02 AM
Thanks for your replies...that pin out will be a BIG help!!
