C.D. Changer
Old Jan 13, 2003 | 03:16 AM
9T9 Annv. TA's Avatar
Default C.D. Changer
I bought a JVC 12 disc changer over the X-mas holidays and I installed it in the hatch on the
drivers side.(Next to where you place the T-Tops
in when you want to store them) I have put 2 foam sponges under the changer to stop the changer music from jumping. It doesn't have to be a real rough road either but if you hit any little bump it'll jump. I have the changer bolted down also
with 4 screws. Where do they mount the changer at from the factory? Do you all have any problem with this? <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Jan 13, 2003 | 08:03 AM
willinwtx's Avatar
Default Re: C.D. Changer
i know it sounds simple but start by checking the horizontal and vertical swich on the sides of the changer., make sure their set the same and on the right position,
Old Jan 13, 2003 | 01:26 PM
I'll try that and thanks alot! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 13, 2003 | 10:37 PM
exSStacy's Avatar
If that doesn't fix your problem you have a defective changer...
