Speakers not playing
Old Jan 22, 2003 | 02:59 PM
SiR Havoc's Avatar
Default Speakers not playing
HELP!!!!!!! my speakers stop playing in my car...i have the moonson system. i had my amp power wire to my 2nd amp just hanging without being connected to the amp...i heard a noise and then i could hear alternator whine trough the speakers but no music....could i have blown the fuse on the monsoon amp
Old Feb 10, 2003 | 11:35 AM
blown 346's Avatar
Default Re: Speakers not playing
You could have shorted out the amp itself. The whine you are hearing might be from bad RCA's, I had this problem and had to replace them. Check your RCA's to see if that helps with the whine. I would check your fuse and see if it is blown, was the noise you heard sound like a thump through your speakers?
Old Feb 10, 2003 | 11:36 AM
blown 346's Avatar
You could have shorted out the amp itself. The whine you are hearing might be from bad RCA's, I had this problem and had to replace them. Check your RCA's to see if that helps with the whine. I would check your fuse and see if it is blown, was the noise you heard sound like a thump through your speakers? I'tcould also be that your power wire isnt getting a good connection check all your hardware and make sure it is all good and tight.
