Has anyone actually replaced the sail panel speakers in a Camaro successfully?
Mine keep blowing and I want to buy a decent replacement that won't blow up on me. 100-150$. I will eventually replace everything but not now.
I hear that the sail panel subs are 4ohm dvc, 2ohm svc, and everything in between. Has anyone actually replaced them with a completely stock system successfully?
If so, what did you use?
Thanks,
Dope
PS-this is crossposted from ls1.com, sorry. No one had any answers there though.
Thanks,
Dope
make sure the ohm rating of yours first. Rockford fosgate makes a 6.5 in sub in the he line. Kicker also make a couple of 6.5 in subs. I have used both and hade good sucsess. another speaker i have used is the blaupunkt overdrive. its a coaxial but the woofer part is great and the speaker can be wired 2 ohm, and the last great. the biggest thing i saw about the monsoon system was the fact that they distorted bad when the bass is turned all the way up, and when a system distorts no speaker is going to last.
