Specs for a 12" sub box
Old Mar 12, 2003 | 01:44 PM
MI_SS_IL's Avatar
Default Specs for a 12" sub box
For the wheel-well or the drivers side enclosure ... does anyone know the specs to build a box for a 12" sub? It will fit, right?
Chris
Old Mar 12, 2003 | 02:37 PM
Sears's Avatar
!Dial-up Director
Default Re: Specs for a 12" sub box
Mine is custom made from a guy on ls1.com ( BJ was his name ). 12" drivers side fibergalss box. I think it is around 1.3^3ft of airspace.
I can take some measurements of it if you like, just email me.
Justin
Old Mar 12, 2003 | 02:57 PM
MI_SS_IL's Avatar
You have mail.
Chris
Old Mar 12, 2003 | 07:24 PM
Biochem's Avatar
Made mine... not hard to do either.
Old Mar 13, 2003 | 04:04 AM
MI_SS_IL's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Biochem:
<strong> Made mine... not hard to do either. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Specs?
Chris
Old Mar 14, 2003 | 08:20 AM
Biochem's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MI_SS_IL:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Biochem:
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It's a 12" MTX sub... but I assume you mean the box <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
It's custom... meaning there probably isn't a straight edge on the entire thing. I made the front and bottom out of some 3/4" MDL (whatever that particle board stuff is called) and the rest out of fiberglass. Fiberglass is not hard to work with and is easy to grind down and re-lay if something doesn't fit quite right. And it doesn't matter if it is ugly or amorphous when it is behind/under the panel... the front is carpeted.
Old Mar 18, 2003 | 06:03 PM
MI_SS_IL's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Biochem:Fiberglass is not hard to work with and is easy to grind down and re-lay if something doesn't fit quite right. And it doesn't matter if it is ugly or amorphous when it is behind/under the panel... the front is carpeted. [/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Is fibreglass hard to make? I have no experience with it. So you used particle board and fibreglass? How's it sound?
Chris
Old Mar 18, 2003 | 09:05 PM
BadAssBlueStripeTA's Avatar
hmmm...I was gonna get a 10in. Stealthbox, but now I'm not sure...I'll have to see how you say it sounds first
Old Mar 20, 2003 | 07:11 PM
Biochem's Avatar
Chris [/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Go to Home Depot and get a can of the resin and hardener... works just like bondo <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Get some fiberglass mat... the finer the weave the better. Basically, the resin is what hardens, but the fiberglass sheet is what basically holds the resin in place until it dries. The amount of (clear) hardener added affects the speed at which the resin dries.
BTW, it sounds great. Thick enough fiberglass makes a pretty sturdy box, which is basically what they make the Stealth box out of too I think. I am 100% happy with it. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 21, 2003 | 07:01 AM
MI_SS_IL's Avatar
<strong> I am 100% happy with it. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Okay, sounds good, I think I'll give it a go. Thanks for the info.
Chris
Old Mar 23, 2003 | 02:07 PM
Scalpel's Avatar
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Go to Home Depot and get a can of the resin and hardener... works just like bondo <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Get some fiberglass mat... the finer the weave the better. Basically, the resin is what hardens, but the fiberglass sheet is what basically holds the resin in place until it dries. The amount of (clear) hardener added affects the speed at which the resin dries.
BTW, it sounds great. Thick enough fiberglass makes a pretty sturdy box, which is basically what they make the Stealth box out of too I think. I am 100% happy with it. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Biochem, is it really that easy to use and work with? Thanks
Old Mar 23, 2003 | 05:33 PM
Biochem's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CANNIBAL:
<strong>Biochem, is it really that easy to use and work with? Thanks </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes. A dermmel tool with a sanding bit will allow you to fix a lot of places which don't fit 100%... try not to breath the dust <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> Like I said, it doesn't matter what it looks like behind the panel or under the front carpet. Feel free to grind, fit, and re-lay the glass a few times until you get it right. It IS that easy... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
EDIT: I tend to pour the resin into a tupperware bowl... cut the fiberglass mat strips into appropriate sizes/strips... add the catalist (clear liquid)... dip the strips in the fiberglass and lay them on the box in the appropriate places. When I am out of strips of glass mat, I pour the remainder of the resin/hardener on the box to harden...
<small>[ March 23, 2003, 05:38 PM: Message edited by: Biochem ]</small>
Old Mar 23, 2003 | 06:03 PM
JB_94_z's Avatar
There are some tech articles here that can help you with fiberglassing basics.
http://www.fbodyaudio.com/tech.php
