wired gauges into dimmer switch and now dash wont light up
i just wired up some gauges in my a pillar and everything worked fine when i just stuck the ground wires on some metal to make sure everything works.
when i went to permanently ground it i turned on the lights and just the gauges and steering wheel lit up. and when i turn on the lights and the radio is suppose to dim it dims out all the way where it isnt even visible.
i took off the ground for the gauges and it still does the same thing. what did i do wrong or **** up?
