power antana
Old Mar 25, 2003 | 01:39 PM
My Camaro's Avatar
Default power antana
i saw a web page and now the url is bad about how to install a power antana and also a overide switch for it so you can play the radio and not have it go up.. but i have not been able to find that page any were... any one have a new url or a how to?? <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Mar 25, 2003 | 07:11 PM
DrMilhouse's Avatar
Default Re: power antana
Remove the old antenna and the shaft for it that is connected to the mount for the spare. After you have that out, mount in the new antenna per the instructions that comes with it.
To set up an over ride switch, just run a wire from an ACC switched item (i.e. the acc switched wire at the deck) to the remote turn on lead for the antenna. Cut the wire you run and install a single on/off toggle or push button switch.
You're done.
Old Mar 26, 2003 | 09:30 AM
Black98SS's Avatar
if you go to blackcamaro.com itll show you how to do it its really simple i got mine done in about 30 minutes and thats with the on/off switch that i put in the ashtray
Old Mar 26, 2003 | 09:44 AM
My Camaro's Avatar
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> thank you!
