Security Light!!!
Old Aug 29, 2006 | 04:43 PM
smg267's Avatar
Default Security Light!!!
I just saw my favorite light again today SECURITY! I just had the entire ignition thing replaced like 4 months ago! WHat does it mean when the light just stays on? Is there a way to disconnect the whole system? Thanks in advance guys!!
Old Aug 30, 2006 | 07:03 AM
WhiteBird00's Avatar
Ungrounded Moderator
You can't disconnect the system because it's part of the BCM which handles a lot of other functions. However, you can bypass it by just inserting the correct resistor between the two leads that go to the steering column. But you should try cleaning your key first. A common cause of problems is grime on the contacts of the key resistor pellet. Use a pencil eraser and then some rubbing alcohol to clean the contacts on both sides of the key and see if that doesn't fix the problem.
Old Aug 30, 2006 | 09:04 PM
peterlawl84's Avatar
Mine has come on and stays on constantly now. I have tried cleaning it but still the light remains. Any ideas?
Old Aug 31, 2006 | 07:20 AM
Another thing you can try (that didn't apply to smg267 because he had replaced the ignition) is cleaning the contacts inside the ignition cylinder. Get a can of spray contact cleaner from Radio Shack and spray it in the ignition cylinder, insert and remove your key several times to rub off any grime loosened by the cleaner, and then dry with a shot of compressed air (either from a shop compressor or one of those cans used for computers).
Also, try your spare key. Sometimes the contacts on the primary key get worn from constant use so they don't make good contact.
Old Sep 8, 2006 | 12:18 AM
SOULPOWER's Avatar
i'll try it this weekend!!
ths!!
Old Sep 14, 2006 | 12:07 AM
what does it mean when the security light flashes and the car will not start? I have tried all three keys I have and all are doing the same thing.
Old Sep 14, 2006 | 01:23 AM
SOULPOWER's Avatar
if it flashes and stay on, then is not reading the resistor, or inside the switch one of the cables is not making contact, that happens onces to me, you will have to open the switch, by taking of the sterring wheel, and weld the cable that is not touching the resistor reader... something like that, just dont know how to explaining :S
