TCS Switch wiring for purge?
TIA <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
After checking the voltage and getting some readings that didn't quite make sense, I tried checking the continuity for power/ground on the switch itself.
Here's a generic pin layout:
ººº
ºº
The top left pin and top middle pin had continuity, and the top right and bottom left pin had continuity. Therefore I assumed the bottom right pin was the accessory. I hooked up the power wire for the purge and used the same ground I had before, but it didn't work.
Any insight here???
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I would greatly appreciate it.
Also, if you can get it for the 3 harnesses on the pass side fender, that would be greatly appreciated as well.
Thanks.
Ryan.
Im assuming you work for a dealer, or similar.
Do you know of any stand alone software that a consmer can purchase to get similar info?
I have similar CDs for ford stangs, but cannot find similar for the f-cars.
Thanks in advance.
Ryan.
