Urgent
Old Apr 6, 2003 | 03:01 PM
Rice Burner's Avatar
Default Urgent
How do I get into my stock head unit? I need to be to work in a hour and I want my system hooked up. I need to hook up RCAs and my remote wire! Help!
Old Apr 6, 2003 | 03:47 PM
Johnny's Avatar
Default Re: Urgent
if it is a transam or camaro you just pop the piece of plastic off around the radio and remove the 2 9/32" screws
Old Apr 6, 2003 | 09:00 PM
NightHawk's Avatar
Default Re: Urgent
This might not help now, but if you're hooking an amp up to your stock deck, you can get all the wires you need in the hatch area. Remote can come from the power antenna wire, which is hot whenever the radio is on, and signal can come from the hatch area speakers or the rear seat side panel speakers(if you want a more non-fading input for your amp ie. subs). It's a lot easier than running wires all around your car. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 6, 2003 | 09:41 PM
Default Re: Urgent
Ok I actually figured out how to do this right after posted this. I figured teyd pop off but i wasnt using enough force, i was scared id break em.
Thanks
