Ground wire???
Old Apr 13, 2003 | 09:33 PM
LS1FenixBird99's Avatar
Default Ground wire???
Does anyone have a 1 farad cap in their systems. i need a better ground and im runnin an alpine V12 4 channel and V12 mono amp off the cap. i need a closer groud. where did u guys ground yours?
Old Apr 14, 2003 | 09:29 PM
DrMilhouse's Avatar
Default Re: Ground wire???
where is your amp mounted?
Old Apr 14, 2003 | 10:42 PM
ALPINE's Avatar
I am using a 4 farad cap, mine's grounded on the rear seat-belt mount.
Old Apr 16, 2003 | 04:41 PM
My amp is right on the flat part behind the rear seats in an amp box. i tried the seatbelt one. and it was a bad ground and i wouldnt get any sound
Old Apr 16, 2003 | 09:56 PM
ALPINE's Avatar
Make sure your grounding to metal and not paint, if you haven't already. If you want to be sure drill you a little hole, and scrape a bit of parint and bolt that sucker in there. But thats where my amp is, and where its grounded(rear deck, seatbelt). Make sure it sparks when you toutch it, if your hot is hooked up of course.
Old Apr 16, 2003 | 11:02 PM
you2slo's Avatar
I grounded my cap directly to the car under the factory amp. Be sure to do lots of sanding for the best possible ground. Make sure NOT to use an iodized bolt or washer.
Old Apr 16, 2003 | 11:30 PM
blown 346's Avatar
I grounded mine to the inside of the driver quarter panel at the back of the car, closest to where the hatch closes down right underneath the carpet.
Old Apr 17, 2003 | 11:01 AM
thanks for the input guys, im gonna go try out some of those spots today.
Old Apr 21, 2003 | 10:13 AM
Tapout's Avatar
Im running a Stinger 3 farad cap. I grounded to the chasis. absoluty no noise! <img src="http://www.fbodyaudio.com/albums/tapout/aby.jpg" alt=" - " /> <img src="http://images.cardomain.com/member_img_a/167000-167999/167887_62_full.jpg" alt=" - " />
