Fog Light Mod Look Here!!!
Old Aug 30, 2006 | 04:37 PM
bjamick's Avatar
Default Fog Light Mod Look Here!!!
http://www.ls2.com/forums/showthread...hreadid=111970
this is the mod to turn the fog lights on anytime you want to. i was sent this but the first step says to cut and replace the brown wire, replace it with what and exactly what do i do??
Old Aug 30, 2006 | 07:44 PM
WhiteBird00's Avatar
Ungrounded Moderator
As the thread says, cut the brown wire (which carries power from the headight/parking light circuit) and connect an ignition controlled power source to it. You can get an ignition source by running a wire (with an inline fuse) from the IGN tap in the fuse panel.
That mod will work fine as written for a Firebird. On a Camaro you need to also cut the light green wire at the switch and connect it to ground. Otherwise the ON indicator light in the switch won't work.
Old Sep 1, 2006 | 04:18 PM
JSmee99T/A's Avatar
im having a hard time understanding this. i have no need for them at any other time. i think my ability to turn them on in stock form meets my needs. just wondering at what times do you need them on to do this mod?
