voltage reading off of RCAs
Old Sep 18, 2006 | 06:26 PM
savethelinoleum's Avatar
Default voltage reading off of RCAs
I installed a PAC SWI-35 onto my factory CD player and I'm not getting any voltage reading off of the RCAs.. (actually nothing off of the ports on the LOC.. so it must not have a good connection)
Anyway the way I understand it a normal reading at normal volume would be something like 50-100mv, but right now I dont have another setup to compare it to... can someone with a multimeter go outside and tell me what the voltage reading is off of their RCAs... it can be a standard setup off of an aftermarket deck.. just anything to give me a range.
Old Sep 18, 2006 | 08:05 PM
Sgt Joe's Avatar
I have an old JVC deck connected on a test bench and I'm getting about 8-11mv at half volume from the RCA's playing Pearl Jam's Alive if that helps you.
Old Sep 19, 2006 | 09:32 AM
awesome.. really appreciate it. man that's a really low voltage, I actually hooked up some RCAs to my headphone jack on my laptop and got a reading of 4-7mv.. i figured it would be higher off of the stereo but thanks a LOT
Old Sep 19, 2006 | 11:11 PM
GPz1100's Avatar
Measuring AC or DC?
Should be on AC, also, is it a true rms meter?
You really shoul dbe hooking up a scope to get any sort of meaningful information.
Old Sep 20, 2006 | 09:09 AM
No I was just using a regular multimeter.. I take it you're saying that's not real accurate..
Old Sep 20, 2006 | 03:04 PM
GPz1100's Avatar
If your audio signal is a 60 HZ sine wave with constant amplitude then the reading you get at your DMM might be correct, but music constists of many frequencies. What you're interested in is the peak of these which your dmm is not likely to pick up unless it's designed for such purpose.
