Whine
Old Sep 19, 2006 | 10:36 PM
Transamin00's Avatar
Default Whine
ugh, i put a filter on the radio, on the remote line to the amp. even a ground loop isolator on the RCA at the head unit. i still get the engine whine that changes with engine speed.
Ideas? should i running a ground from the battery? i need help
Old Sep 19, 2006 | 10:46 PM
burnzilla's Avatar
Inadequate Ground.
Old Sep 19, 2006 | 11:09 PM
Originally Posted by burnzilla
Inadequate Ground.
take a dedicated line to the battery, or just a to a better point in the rear of the car?
Old Sep 20, 2006 | 05:58 AM
wickedwarlock's Avatar
Affirmative, a good ground is the seat belt bolt.
Old Sep 20, 2006 | 09:47 AM
unfortunatly for me, thats where it is attached. with a 6gauge wire. thats why i dont understand it and need a little more help
Old Sep 20, 2006 | 10:25 AM
That's where mine is, get a screwdriver out and scuff the metal. The coating is blocking the flow of power, lol.
Old Sep 20, 2006 | 10:30 AM
Revelation Z28's Avatar
you mean the whine/static from the speaker as the rpm goes up?
i have that too.. prev owner has one hell of a system in this car.
Old Sep 20, 2006 | 11:28 AM
ill try that after work and get back to ya, thanks
Old Sep 20, 2006 | 02:41 PM
sgt0704's Avatar
make sure your rca cable isn't ran next to your power cable. i had the same thing. i changed the ground, and moved the rca cable to the center of the car, that helped a lot, but then i added the ground loop isolator, and it went away completely.
Old Sep 20, 2006 | 03:45 PM
i might have done that from the mid point back, ill have to check and see
Old Sep 20, 2006 | 06:24 PM
GPz1100's Avatar
I have no noise in my stereo, static, whine or otherwise. No ground loop isolators, no direct to battery power feeds for the HU, etc..
sgt0704 is correct above about having your rca's not near your power wires.
What you need to determine is if the noise is being induced at the HU level or at the amp level.
The easiest way to do this without tearing anything apart is to use a ipod or similar as your source, plug that in directly to the amp in the back.
If you have no noise with the engine running then you know it's between the HU (included rca's) and the amp. If noise is present then check where you have your power cable run.
I have mine entering from the grommet near the pcm, and along the passenger door sill.
The rca's are along the hump on the driver side.
If the noise is at the HU, then you need to determine if its being picked up by the Hu or rca's. PLug your ipod into the rca's at the HU and see what happens.
I really don't buy the whole bad grounds thing. I'm using the factory wires for my power, gnd and memory feeds. Of course, this assumes a proper installation. Any painted surfaces with attached wires was sanded down to bare metal before installation, properly crimped, or better yet soldered terminals, etc.
Do some more testing to determine the source....
Old Sep 20, 2006 | 11:26 PM
wicked, you the man, thanks buddy
Old Sep 21, 2006 | 09:25 AM
I take it that worked for you. Congrats and Your welcome anytime. The ground is the fix 95% of the time.
And those others who have posted are correct in additonal steps to take if you were still having a problem.
