Headlight Switch
Old Sep 24, 2006 | 10:50 AM
Huff035's Avatar
Default Headlight Switch
I own a 1995 Pontiac Trans Am and when I turn on just the fog lights and parking lights the headlights come up as well, but they are not on. Someone told me that I have a bad headlight switch, Are they right? Where can I get one?
Old Sep 24, 2006 | 01:42 PM
WhiteBird00's Avatar
Ungrounded Moderator
It's remotely possible that it's the switch but it's more likely a stripped gear in one or both of the headlight motors. Do you hear a grinding sound when you turn the headlights on or off? This is a fairly common problem on Firebirds and it has a variety of symptoms such as what you're experiencing or having the headlights pop up and down when arming the alarm system.
Old Sep 24, 2006 | 08:03 PM
Huff035's Avatar
Yeah, When I turn the headlight off it makes a grinding sound. Someone suggested bying a rebuilding kit from like Rodney Dickman or something. That is $70 to fix both of them. So if I buy the kit to fix them that will keep the headlights from popping up when just the foglights are on?
Old Sep 25, 2006 | 08:34 AM
You don't want to replace the original gears with more plastic ones - they'll just strip again. You can buy brass replacement gears that should last forever. Brass gears and instructions are available here.
Old Sep 25, 2006 | 05:23 PM
Huff035's Avatar
The gears that are on that site are brass gears, so is that what I should get?
Old Sep 25, 2006 | 07:08 PM
Isn't that what I said?
