12 disk changer woes
Symptoms.
When playing a disk from the 12 disk changer, an elctronic noise will develop and the right channel sound becomes mostly muted. The noise sounds electronic in nature, sort of like a beep/tick sound. The noise is very periodic in nature but is not heard when playing the same disk on the main head unit itself. So the problem seems to be with the cd changer itself.
Remedies.
In the past when it first appeared, it would happen once in a blue moon and all I would have to do is turn off the radio and back on and it would go away. As time passed, I had to start turning off the radio, then turn off the car and it would go away.
Recently the problem has been continuous in nature at every time I try to use the changer. Turning off the radio, car and back on does not fix the problem.
Has anyone ever heard of this problem before? (Yeah, I know that Monsoon should of been named "bug ridden" ) This is the only trouble with the monsoon I have had since delivery in '01. Any help would be much appreciated
I'll give it a shot
