Monsoon question
Old Sep 28, 2006 | 12:51 PM
delsold's Avatar
Default Monsoon question
hey, i read through the sticky..but couldnt find what im looking for.
I have the monsoon sound and love it, but want some more bass. I got a jbl 12" and a nice amp from a good friend for 50 bucks. Does the monsoon HU have rca outputs on the back?
Old Sep 28, 2006 | 02:30 PM
ironexecutioner's Avatar
hey man, hows it treatin ya? just to tell you, unless you swapped it out I don't believe you have the monsoon in there. could be wrong but im pretty sure I am not
Old Sep 28, 2006 | 03:06 PM
jimmy 2 Times's Avatar
no, it does not have rca's.
go to best buy and pick up a line level converter, or you can get a more expensive one from pac
Old Sep 28, 2006 | 09:18 PM
delsold's Avatar
thanks guys....what exactly is a line level? and how much would they cost me?
...iron its treating me real good...i love it. and i think it definitely has the monsoon, it has the 10 speakers, the eq, the amp in the spare tire wheel, i didnt think the other system had all those...i could be wrong? my friend has the monsoon in his, and it looks identical to mine.
hows the camaro?
Old Sep 28, 2006 | 10:08 PM
Caswell's Avatar
A line level converter takes a high-level (speaker) output and converts it to a low-level (RCA) output. They're not terribly expensive - should be around $20 or so.
Does the amp have speaker level inputs? If it does, you may not need a seperate line level converter.
Old Sep 28, 2006 | 11:28 PM
delsold's Avatar
thanks
im not sure about the level inputs, ill hafta check when i pick the sub and amp up this weekend.
Old Sep 29, 2006 | 07:54 AM
Hey man, camaro is good. The head unit in your car doesn't look like a monsoon.. that's what made me unsure. It should say monsoon on it, and it doesn't, it is styled slightly different. But yeah everything else sounds like its the monsoon... I am unsure now haha. Get that thing to the track yet?
Old Sep 29, 2006 | 02:37 PM
delsold's Avatar
ya thats why i wasnt sure it did, until i found the amp, and noticed all the speakers...no track runs yet. brought it on the dyno at school though 287whp and 307ft lbs on the mustang dyno. I did a simulated 1/4 mile on the dyno 15.1 at 111 with a 1.960ft....ha peak torque + metal dyno = no second gear traction at all
picked up some long tubes (which i wanna trade + cash for shortys) a ory, ls6 intake, throttle body, and a comp cam that ill install over the winter
track in the spring
