Horn doesnt work, fuse is good.
The black wire in the 7th position is the correct one as is the one in the 4th position of the column connector. You should see that there are actually two black wires in that column connector 4th position because that's where the wire from the BCM connects to the circuit.
I don't know of any way the panic alarm can be turned off but the panic alarm was only available with option code UA6 - the vehicle alarm system. If the car has only keyless entry without the alarm system then that would make some of your results make more sense. If that is the case then I'm afraid you'll have to remove the steering wheel to do any more diagnostics. You'll have to test for good contact at the slip ring and continuity in the horn switches.
Try applying ground to the black wire at the steering column connector using a jumper wire - the horn should blow. That way you'll know that the wiring from the column to the relay and then to the horns is good.
I would test the horn switch first before going to the trouble of removing the wheel to test the contact ring. Just remove the pad and you'll see the switch with a yellow and a red wire (one switch has two contacts to handle both sides of the pad). Try applying ground to either of those wires using a jumper wire. If the horns blow then you'll know the switch is the problem and you won't have to worry about the contact ring.
There are four #30 Torx bits on the back of the steering wheel that hold the pad on. Remove them and the pad will come right off (except for the electrical connectors).
