Oil Temp Gauge
What exactly is involved in the installation of one, I am very confused. Do I need to tap a hole anywhere or can i piggyback off of another sensor?
I tried searching and am still confused.
Another option is a diverter plate that is right above your oil filter. It is held on by two 10mm bolts. Take that off and tap it and mount you sender in that. I bought a Corvette plate that is already pre-drilled. I haven't mounted it yet. I couldn't order the non-drilled one that come on Birds/Maros. I just wanted one to drill into an extra one so I didn't screw up the only one I had.
