alternator/starter question
Old Oct 9, 2006 | 08:34 AM
Smokingss's Avatar
Default alternator/starter question
ok, my ls1 blew up a lil over a year ago and the car sat about 9 months till i finally pulled the engine. My question is, should i have the alternator checked out or anythign done to it, or should it be fine just to put back on the new motor. When i first took it out again, it felt tight to turn and almost hung up but then suddenly it freed up and now spins fine. My concern is also for the starter and any issues i may have with that. Any opinions/advice?
Old Oct 9, 2006 | 04:30 PM
WhiteBird00's Avatar
Ungrounded Moderator
Unless it was sitting outside with the hood off (exposed to rain, etc.) it should be fine.
Old Oct 9, 2006 | 05:36 PM
Smokingss's Avatar
Car was outside, but hood was on and all, but it did sit from august 2005-march 2006 with a flat tires and its lowered quite a bit.
Old Oct 9, 2006 | 10:56 PM
Grimlock's Avatar
If you have the funds, while everything is out you might as well go with upgrades on those two so you will have piece of mind and wont get stuck out in the middle of BFE. That is ONLY if you have the funds.
Old Oct 10, 2006 | 12:08 AM
dragonrage's Avatar
Test 'em for free at Autozone
Old Oct 10, 2006 | 12:12 AM
Grimlock's Avatar
Thumbs up
...and then get your parts there in case you need one sometime in the future. That life time warranty/guarantee really works! No questions asked, just bring your core.
