Stereo Noise
Old Oct 11, 2006 | 04:38 PM
RedHawk98's Avatar
Question Stereo Noise
I recently installed a new stereo in my 98 T/A. I installed, a Sub, and two amps. I had the head unit and the speakers installed prior to this install. The problem I'm having is alternator whine. I don't want to buy a new alternator yet cause I want to check all my grounds first. I have a couple of questions maybe you guys could help me with.
Before I even added this stereo, I was having problems with my battery holding a charge if I let the car sit for more then 12 hours it would go dead on me.
Then I thought it was the battery and I replaced it and it still wouldn't hold a charge. I noticed after I installed the head unit and speakers that when i would shut the car off the speakers would pop. Well now that I have installed an amp for the aftermarket speakers. I have solved the popping problem that I had. Every time i use one of the powered accessories in the car, like windows, breaks, or anything like that I here the whine, not to mention the wine I get when the rpm's clime.
So do I just need to ground everything better, or do I need to get a new alternator? Also if its a problem with the ground, where is a good place to ground an amp in the trunk? I have it grounded right now to the same ground as the trunk release.
Old Oct 11, 2006 | 11:08 PM
volcanic2345's Avatar
redo all of your grounds, get some sand papper and use it to rub paint off then ground again, i have my grounds in trunk under the carpets, make sure you ground everything seprate and if it cont. try a noise filter! oh and if you have the ground with trunk release then it might not be strong enough!
Old Oct 15, 2006 | 11:51 AM
RedHawk98's Avatar
Lightbulb figured it out
I figured it out the damn amp that I bought had a blown channel, and I also had a problem with the remote wire grounding out near the head unit. I appreciate the help though.
