best place to hide an amp ??
Here are some pics from my install. For the most part, everything is concealed when the trunk is closed and the rear hatch cover is covering the trunk area.
https://ls1tech.com/forums/showpost....68&postcount=5
If you don't have a CD changer maybe you could mount your amp in the cubby hole on the left side at the back - relatively out of the way but still gets air flow.
I would suggest you just mount it on the rear tail lamp wall. It will be concealed just as well as your sub so long as you use the hatch divider panel. Fairly easy to do, good looking location, not obvious to peekers. (at least not more so than the sub)
IMO where the amp rack is installed on that back piece is the best place to mount an amp. Its out of the way from the ttops if done right, is stealthy since it is covered by the trunk, and it has the best breathing room.
PS...my ttops fit perfectly and the amp still has a few inches even if I hit a bump and the ttops move.
